the 240SX Bible Volume 1 which consists of a collection of DIYs, How Tos, FAQs, Install Guides, and General Info...
Electronics/ECU
ECU pinout diagrams. (
http://forums.nicoclub.com/zerothread?id=126070)
REWIRING YOUR IGNITION COIL (
http://www.ka-t.org/ignitionrewire.htm)
Distributor Timing (
http://forums.nicoclub.com/zerothread/161707)
Removing speed limiter on 93 KA24DET (
http://forums.nicoclub.com/zerothread?id=133834)
DIY Ignition Mods for Better Spark (
http://forums.nicoclub.com/zerothread?id=127078)
Sr20det Ecu Fault Codes (
http://www.240sxforums.com/forums/showthread.php?t=434)
SR20DET ECU wiring diagram. (
http://www.240sxforums.com/forums/showthread.php?t=433)
FAQ: KA ECU # Glossory (
http://eccs.hybridka.com/viewtopic.php?t=207)
A long tutorial for tuning nissan's ECUs (
http://eccs.hybridka.com/viewtopic.php?t=47)
How-To: Chip Your ECU with Pictures (KA24E) (
http://eccs.hybridka.com/viewtopic.php?t=149)
Desoldering tips (
http://eccs.hybridka.com/viewtopic.php?t=122)
Battery Relocation (
http://www.my240.com/index.php?paren...y%20Relocation)
Engine/Engine Info
SETTING THE BASE TIMING ON THE DOHC PROPERLY (
http://www.ka-t.org/basetiming.htm)
How to build a KA24DE (
http://www.ka-t.org/forums/viewtopic.php?t=4156)
How to: S13 Oil pan removal (
http://www.ka-t.org/forums/viewtopic...il+pan+removal)
DIY: HOW TO REPLACE YOUR DRIVE BELTS ON S13 / 91-93 240SX SE / KA24DE (
http://forums.nicoclub.com/zerothread/120780)
How-to: Build Your Own Oil Cooler (
http://forums.nicoclub.com/zerothread/167442)
S13 Red Top Vs. S13 Black Top - The differences (
http://forums.nicoclub.com/zerothread/49836)
DOHC Turbo For Dummies (
http://www.ka-t.org/forums/viewtopic.php?t=6263)
240sx Engine Descriptions (
http://forums.nicoclub.com/zerothread/37526)
240SX How To: Removing/Replacing your PS pump (
http://forums.nicoclub.com/zerothread/178549)
DIY: ITB's for your KA24DE (
http://www.240sxforums.com/forums/sh...ad.php?t=58363)
Basics of engine management (
http://eccs.hybridka.com/viewtopic.php?t=152)
SR20DET Installation Guide (
http://www.heavythrottle.com/)
1993 240sx Capacities and Specifications (
http://forums.nicoclub.com/zerothread/159816)
HOW-TO: Fix Your Timing Chain Rattle (
http://forums.nicoclub.com/zerothread/105618)
KA24e to KA24de swap - Step-by-step. (
http://forums.nicoclub.com/zerothread/162443)
240sx (S14) HotShot header install (
http://forums.nicoclub.com/zerothread/162346)
Does my 240sx have a bad O2 sensor? (
http://forums.nicoclub.com/zerothread/161680)
240sx knock sensor replacement (
http://forums.nicoclub.com/zerothread/160234)
How to do a compression test on your engine (
http://forums.nicoclub.com/zerothread/159838)
RB25DET into S13 Installation (
http://forums.nicoclub.com/zerothread/74700)
Engine Knock (Detonation) Sensor Replacement (KA24DE) (
http://www.socal240sx.org/articles.html)
Transmission
How To: Convert from A/T to M/T (
http://www.ka-t.org/forums/viewtopic.php?t=1935)
How to Swap Your Auto Transmission for a 5-speed (
http://forums.nicoclub.com/zerothread/183606)
Changing transmission fluid / oil on s13 (
http://forums.nicoclub.com/zerothread/95826)
How to install paddle shift on an automatic 240SX (
http://forums.nicoclub.com/zerothread/179677)
240sx Clutch and Flywheel Swap (
http://forums.nicoclub.com/zerothread/168578)
S14 auto -> manual with pics (
http://www.240sxforums.com/forums//s...ad.php?t=83012)
Clutch Swap (
http://www.my240.com/index.php?paren...=Clutch%20Swap)
Fuel/Nitrous
REWIRING YOUR WALBRO 255 FUEL PUMP ON S14's (
http://www.ka-t.org/walbrorewire.htm)
240sx: Installing a Walbro Fuel Pump (
http://forums.nicoclub.com/zerothread/180256)
240sx: Replacing Your KA24DE Fuel Injectors (
http://forums.nicoclub.com/zerothread/179894)
DIY: Installing an injector resistor box (
http://forums.nicoclub.com/zerothread?id=119383)
Nitrous Oxide FAQ (
http://forums.nicoclub.com/zerothread/116962)
Turbo
HOW TO NEVER OVERBOOST AGAIN (
http://www.ka-t.org/overboost.htm)
Bobby's DIY turbo oil feed/return lines install (
http://forums.nicoclub.com/zerothread?id=140446)
Turbo rebuild DIY (
http://forums.nicoclub.com/zerothread/178185)
Turbocharging your automatic-trans car (
http://forums.nicoclub.com/zerothread/162939)
Suspension/Differential/Brakes
Changing differential oil/fluid, 92 240sx, synthetic gear oil, open differential (
http://forums.nicoclub.com/zerothread/114085)
The Definitive 300ZX Brake Swap! (
http://importnut.net/300zxbrakeswap.htm)
Advanced Suspension Definitions (
http://forums.nicoclub.com/zerothread/168586)
Rear differential swaps for the 240sx (
http://forums.nicoclub.com/zerothread/168561)
Rexbo’s Guide to the s13 to s14 Front 5-Lug Conversion (
http://www.240sxforums.com/forums/sh...ad.php?t=82468)
Rexbo's Guide To Brake Caliper Rebuilding (
http://www.240sxforums.com/forums/sh...ad.php?t=81611)
240sx curb weights (
http://forums.nicoclub.com/zerothread/161948)
All you ever wanted to know about differentials (
http://forums.nicoclub.com/zerothread/160237)
Upgrading to J30 Brakes (
http://forums.nicoclub.com/zerothread/175773)
ABS Removal (
http://www.my240.com/index.php?paren...=ABS%20Removal)
Interior
Removing the S13 Door Panel Fabric (
http://forums.nicoclub.com/zerothread/175775)
Low-budget seat modification for S13 (
http://forums.nicoclub.com/zerothread/168588)
Re-covering Your S13 Glove Box (
http://forums.nicoclub.com/zerothread/167288)
DIY: Window regulator repair 5$ (
http://www.240sxforums.com/forums/sh...ad.php?t=84794)
DIY: Dye That Ugly Carpet!!!!! W/pics (
http://www.240sxforums.com/forums/sh...ad.php?t=67967)
Water leaking into trunk (240sx fastback) (
http://forums.nicoclub.com/zerothread/161947)
Camera Mount (
http://www.my240.com/index.php?paren...Camera%20Mount)
Exterior
HOW TO: Repaint Headlight Housing (Black) (
http://forums.nicoclub.com/zerothread/186872)
DIY: Replacing Your Rusted Hatch (
http://forums.nicoclub.com/zerothread/30178)
240sx Conversions - An Introduction (
http://forums.nicoclub.com/zerothread/172989)
Sleepy Eyes walkthru (VID) (
http://www.240sxforums.com/forums/sh...ad.php?t=57608)
240sx Vented Hood DIY (
http://forums.nicoclub.com/zerothread/168601)
Rust removal, Fiberglassing, and Body Filler (
http://www.240sxforums.com/forums/sh...ad.php?t=81700)
DIY: Silvia Foglight Wiring (
http://www.240sxforums.com/forums/sh...ad.php?t=68288)
All-red S13 Taillights (
http://forums.nicoclub.com/zerothread/172312)
Restoring your Nissan's paint (
http://forums.nicoclub.com/zerothread/159905)
240sx power antenna repair (
http://forums.nicoclub.com/zerothread/159903)
Article: General car cleaning/detailing tips (
http://forums.nicoclub.com/zerothread/158146)
Factory Service Manuals/Diagrams
Factory Service Manuals (FSMs) (
http://www.knight-stalkers.com/dload...egory&cat_id=3)
Your home for factory service manuals (
http://carfiche.com/)
Parts Lists / Diagrams / Setting Sheets (
http://www.knight-stalkers.com/dload...egory&cat_id=8)
HowStuffWorks Articles
How Manual Transmissions Work (
http://auto.howstuffworks.com/transmission.htm)
How Differentials Work (
http://auto.howstuffworks.com/differential.htm)
How Turbochargers Work (
http://auto.howstuffworks.com/turbo.htm)
What is the difference between a turbocharger and a supercharger on a car's engine? (
http://auto.howstuffworks.com/question122.htm)
How Car Engines Work (
http://auto.howstuffworks.com/engine.htm)
How Clutches Work (
http://auto.howstuffworks.com/clutch.htm)
How Car Computers Work (
http://auto.howstuffworks.com/car-computer.htm)
How Fuel Injection Systems Work (
http://auto.howstuffworks.com/fuel-injection.htm)
How Car Suspensions Work (
http://auto.howstuffworks.com/car-suspension.htm)
How Anti-Lock Brakes Work (
http://auto.howstuffworks.com/anti-lock-brake.htm)
How Master Cylinders and Combination Valves Work (
http://auto.howstuffworks.com/master-brake.htm)
What does it mean when a car has dual overhead cams? (
http://auto.howstuffworks.com/question562.htm)
How Camshafts Work (
http://auto.howstuffworks.com/camshaft.htm)
Found it from Tomek @ Ka-t.org, thought someone might find it useful
