Go Back   240Atlanta.com > Technical > DIY > Vehicle Exterior
Forums Register FAQ Chat Donate Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 01-14-2009, 12:48 AM
SCato's Avatar
SCato SCato is offline
Official 240Atlanta Geek
Moderator
Send a message via AIM to SCato Send a message via Yahoo to SCato
180sx position/bumper light install
when you get a kit or change to a type x front bumper you will need to wire in the front bumper turn signals. here is everthing needed:
housings:
new bulb harnesses:
you will also need wire cutters, electrical tape, and soldering gun if you have one.
start off by pulling out the harness on the car for the bumper light and cut it off.
as you can see there are 3 wires; black, green/yellow, red/blue. strip the covering from the two colored wires, and then again on the new light harness. i trimmed the black and taped it over by itself with the electrical tape. then coneect the old light harness and then new one:
plug in the bulb and make sure it works for the driving lights and blinks for turn signals.
Tape everything back up, and tuck back in the harness into the bumper. put the new bulb into the new bumper light, and you are all done!
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Skin Designed By - Illusion-GFX.com
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
