Thread: battery relocated
Results 1 to 7 of 7
  1. #1 battery relocated
    athens GA
    ok so this weekend i put the battery in my trunk finished everything up got in to start it and the only thing that happend was the lights starts going up and down and the rpm gauge went crazy but no start. I tried to jump start it off by the battery and still nothing happend. then i put the jumper cable on were my new pasitive connects to the old one. it workd started to run..... then i cut it off after a while and wouldnt start back up. could it be the ground in the trunk? we checked it with one of thoose things it says it was good but im not sure. i also charger the batter for like 5 hours still nothing. could my battery not be strong enough to send enough volts for it to start????????????
    Lifes slow and dull
    its taking too long to hit vtec
    Its a grounding problem... Maybe find a multimeter and test the resistance in between your grounds?
    Did you clean off the paint where you grounded the ground wire? Did you cut any of the alternator wires in order to run the power back up front? Where did you run the power wire from the battery to?
    athens GA
    ok thanks alot i fixed it befor even looking at this i forgot to ground the motor to the chasis i just grounded the battery so now it works still kinda a slow start im gonna go buy a new strong battery and recomendations it needs to be all amps for starting cause i have no ac radio bla bla.
    Lifes slow and dull
    Reminds me I need a new one as well. It doesn't like to start as much when it's cold...
    Glad you got it figured out.
    Floating in JDM land
    glad u got it fixed. u should get a red top for motor
    hm..
    where did you get the cables to re-mount the battery?
    i'd love to rearmount my battery, but leaky hatches ftl!
    i actually NEED to rearmount my battery soon.. so pooey (ka-t )
  1. Nikon D90 Body only w/ MB-D80 battery grip and extra battery
    By KPFphotography in forum FS - Non Car Related Items
    Last Post: 05-12-2011, 03:29 PM
  2. Repost from IA: Sonic Gwinnett Meets Relocated
    By Deuce_FawtyySX in forum Get Togethers / Events
    Last Post: 01-30-2010, 05:58 PM
  3. Replies: 17
    Last Post: 09-10-2009, 09:07 AM
  4. Battery
    By FCJohnny in forum Interior, Exterior & Electrical
    Last Post: 10-14-2008, 10:17 PM
  5. Charging a 6V battery using a car battery?
    By 04GeeTee in forum Off-Topic
    Last Post: 12-25-2007, 10:51 PM
