Thread: Speaker Harness 95 s14
Results 1 to 10 of 12
  1. #1 Speaker Harness 95 s14
    Apr 2012
    Hey i bought some alpine speakers and when i went to install them into my doors and rear, i saw on my stock speakers that theres a white plastic harness holdering thing that connects to the 2 prongs on the speakers and on the apline speakers theres just the prongs, theres nothing to connect the harness to. is there another part i go buy or do i have to cut the wires and solder them on to the 2 prongs.
    Thank you
    Sep 2010
    Acworth, Ga
    Your speakers should have came with the wire that connects to the prongs on the speaker. Just cut the plastic off and wire them in to the new wire from the speaker. Use wire nuts or butt connectors to connect them.
    ^ what he said.
    Also, if you are using an aftermarket head unit you should consider bypassing the stock amplifiers.
    Dug this write-up out of the past for you.
    http://240atlanta.com/forums/showthr...udio-amplifier
    Apr 2012
    Attachment 33342Attachment 33343Attachment 33344
    ^ is the aftermarket speakers like connectors and the other two are the oem ones so since i didnt for some reason get connecters for the adapter with my speakers, should i just cut the 2 wires of the harness and rap them around the 2 prongs and solder them? would that work or no?
    Go to walmart and buy terminals that slide onto your new speakers.
    then cut the wires and crimp / solder them to the new terminals.
    its really janky to solder the wires straight to your speakers. just saying..
    Apr 2012
    what does Janky mean?
    Apr 2012
    well, i went to walmart and bought a bunch of the terminal things, Basically what you guys are saying are.. 1. Cut the wires right at the harness connected to my car. put the terminals on the two prongs of the speakers and then solder the wires on the terminals.
    Sep 2012
    newnan
    What they're saying is, your alpines should have came with the connector that plugs into the speaker. Unless you bought them used.
    Sent from my PG86100 using Tapatalk 2
    Kennesaw/Norcross
    Quote Originally Posted by BJP Zenki View Post
    Ghetto/shitty.
    1. Cut off the white plug
    2. Strip the ends of the wires that used to be connected to the white plug
    3. Attach your connectors to the wires by crimping or soldering them. You should end up with something that looks similar to this. (Ignore the red connectors in the picture)
    4. Attach the connectors to the proper terminals on your speaker.
    It's pretty simple wiring man, you're making it more complicated than it needs to be.
    Apr 2012
    Quote Originally Posted by chadillac View Post
    I bought them from Best Buy lol. brand new.
  1. WTB: S14 rear speaker panel
    By ds14 in forum Private "Wanted" Classifieds
    Last Post: 03-20-2012, 12:03 AM
  2. wtb: factory speaker amp for s14!!!!
    By greasemonkey in forum Private "Wanted" Classifieds
    Last Post: 09-28-2010, 10:56 PM
  3. FS: Comp Speakers, Sub, bar speaker
    By zebrafantastic in forum FS - Non Car Related Items
    Last Post: 12-17-2008, 10:25 PM
  4. speaker size
    By Elizabeth Reed in forum Audio, Video & Security
    Last Post: 06-10-2008, 05:16 PM
  5. 10" JL Audio speaker box. $30
    By Iam99x in forum Parts/Items For Sale
    Last Post: 05-11-2008, 02:01 AM
