Thread: Rocker Arm Stoppers Install
Results 1 to 2 of 2
  1. #1 Rocker Arm Stoppers Install
    Overview:Rocker Arm Stoppers (or RAS's for short) are a must for any SR20DET. They're pretty cheap, easy to install, and will prevent bent valves. Think of this as an insurance policy for your SR20.
    Tools:
    1. 10mm socket
    2. FSM
    3. Liquid Gasket, pref high temp
    4. Tq. wrench
    5. Spark Plug socket
    Materials:
    1.Rocker arm stoppers
    2. New valve cover and spark plug gasket (if not re-using the old one)
    Procedure:
    First, as always, disconnect your battery before servicing your vehicle. Drain your oil. Also disconnect the air-line to the factory oil catch-can and remove the line that goes to the throttle body.
    Now start removing the 10mm valve cover nuts. There should be 13 in all (5 on either side and 3 down the middle.
    Be very careful as you don't want to get any debris in your head.
    Begin to loosen the cam bolts in alternating order, ie: loosen the front two then the back two, etc. The FSM details exactly how to remove them.
    You're going to remove the "outside" cam bolts but you still want to loosen the "inside" bolts as well. Keep the bolts in proper order as you take them out.
    The "fingers" of the RAS's will sit down inside the head and sit just above the rocker-arm. Now you see why they're called Rocker Arm Stoppers.
    Tighten the bolts. Factory spec is 8.7 ft-lbs, from the fsm
    The "driver" side is very similar with the exception of this oil baffle. After a search on NICOClub, I found that some owners remove the baffle. Others cut it down for fear of blow-by. Since I have the time and tools, I am going to cut mine.
    Removed, as you can see the curves on the end will get in the way of the RAS's.
    After a little time with the Dremmel, the edges are now flat. install the baffle on top of the stoppers. Be sure verify that the new cut is nice and smooth, you don't need any metal shavings in your head.
    Again this part seems to be optional as some owners have just thrown theirs away. If you don't have the tools or if the baffle is already missing, don't sweat it.
    installed:
    All finished.
    Please follow all safety precautions when servicing your vehicle. Failure to do so may result in expensive damages to your car and injury to yourself. This write-up was done in good faith to assist other auto enthusiast. Please check the factory service manual and your local dealer before attempting any work on your car.
    Borrowed from NICOClub
    Aug 2007
    Sandy Springs/Dunwoody
    thanks for the writeup. I am getting som RAS installed soon. Z U L8ter told me about them and they are part of the upgrades im performing. Thanks
    5 reasons why I'm convinced that my penis runs Linux.
    1. I can create child processes
    2. I can handle multiple users on any platform at once.
    3. I'm VERY user friendly.
    4. I have incredible uptime.
    5. When my system load gets too heavy, I end up dumping my core and the system shuts down.
  1. SR greddy rocker arm stoppers
    By Matt geo in forum Parts/Items For Sale
    Last Post: 12-24-2010, 10:10 AM
  2. FS: SR20 rocker arm stoppers
    By cb7tuner in forum Parts/Items For Sale
    Last Post: 07-07-2010, 05:33 PM
  3. Rocker arm stoppers
    By Blake in forum Private "Wanted" Classifieds
    Last Post: 02-23-2008, 02:49 PM
  4. ras rocker arm stoppers sr20det
    By v-empire in forum Parts/Items For Sale
    Last Post: 09-23-2007, 09:25 PM
  5. Replies: 2
    Last Post: 02-04-2007, 12:12 AM
