Thread: Enthalpy + safc2(fine tune)
Results 1 to 5 of 5
  1. #1 Enthalpy + safc2(fine tune)
    Mar 2009
    KA-T FTW
    Ive been using enthalpy to tune my KA-T for the past 6 months. But ive recently changed my setup from 93oct to E85 so i had to send my ecu back to Martin(enthalpy) to get it re-tuned. And I drove around on my new E85 tune for about 2 weeks. And I decided to get my safc2 wired in to help fine tune with. But I couldnt figure out the correct maf sensor(safc2 setting) IN & OUT. Martin told me that 2 IN & 2 OUT is the correct setting since he already incorporated my z32 maf into my ecu tune. But the car wont idle/run with the 2 IN & 2 OUT, The closest match that ive found is 4 IN & 7 OUT. But the car still acts like it has a boost leak or something, It gain/loose power around the 2k rpm range, So if anyone has any suggestions please let me know. My current setup is z32 maf, t3/t4, 850cc, fmic, exhaust, E85!!!!
    S14se=JN1AS4
    Roswell
    2 in 2 out is what is required if your ECU is already tuned for a Z32 MAF. Assuming it is tuned for the Z32 MAF then you have some other issue, you wired the SAFC wrong or something else.
    "I'm too drunk to taste this chicken" - Late, Great Colonel Sanders.
    Mar 2009
    KA-T FTW
    I went through and performed a sensor check on the safc2 and it all came out to be correct. So now im pretty much lost.
    S14se=JN1AS4
    Roswell
    safc's are shit anyways, take it off. If the car runs fine without it, which it should since it has an Enthalpy tune, then just leave it alone.
    Mar 2009
    KA-T FTW
    Quote Originally Posted by Broke240 View Post
    My car didnt want to idle at first, thats the whole reason I decided to install the safc. I figured if I took a little fuel out there it would help the idle out. And it did help the idle out, but it screwed up my particial throttle...lol.
    S14se=JN1AS4
  1. JWT vs Enthalpy
    By afkouki in forum Interior, Exterior & Electrical
    Last Post: 08-19-2011, 01:02 AM
  2. Replies: 3
    Last Post: 08-08-2011, 10:39 PM
  3. RS enthalpy tunes
    By southernjake in forum Motor & Accessory
    Last Post: 03-23-2011, 05:58 PM
  4. 550cc injectors, and z32 MAFS install, and enthalpy tuned ECU
    By evan1242 in forum Power & Performance
    Last Post: 08-27-2010, 11:15 AM
