First off thanks for reading. I have a S14 with the z32 30mm brakes front and rear. I have been driving the car now with this set up for about two years but with out an e-brake. I recently bought the R33 brake cables and decided I would throw them in...no big deal right? Well I got the rear hubs and everything apart only to discover that the RR hub is too large for the axle and the axle just spins freely inside the hub!! The only way I was able to drive it was because the axle nut was installed without a washer and created enough tension to lock it all together (I've done two track days like this...little scary). Well the issue that I have now is I need the 300zx wheel bearing assembly to support the e-brake shoes but is that the right hub? Did I have a twin turbo hub on the RR and that's why it is too large? I'm a little lost and I can't find any definitive info when I search. So if anyone knows for sure or has some parts they think would do it, please let me know!! Thanks!!
