11-12-2009,05:07 PM
Originally Posted by
Viperbite
could be knock sensor
---------- Post added at 07:09 PM ---------- Previous post was at 07:09 PM ----------
or mafs, vac leak. throttle position sensor. or idle air control valve.
probably vac leak
I agree with viper. I will add dont drive it alot . When these kas start acting up something bad usually happens . headgasket, hydrolock, rod knock then sling and kaput. I am about to join the sr crew .Yeah i said it . I am done with kas after two
---------- Post added at 04:07 PM ---------- Previous post was at 04:04 PM ----------
kevr1
Lately the car would start shaking on idle and stay on 1k or above. When I smash the gas it moves slow as hell, then out of nowhere power comes back, then goes away again..etc.
Also theres seems to be some type of clicking/chugging sound when i give it gas, and then it randomly goes away when the power comes back.
Its all stock, plugs and wires are almost new.
Unplug your idle control valve and start car. To start you will need to tap gas . See if it smooth out. keep in mind it will not idle with it unpluged.. Check voltage on tps with voltmeter see if bad. You need any of these piece i am pretty sure i got some boxed up .
I got the FSU on it if you need it . I can zipp it send to ya or ftp it to you
single stage paint jobs 350 if use one of my house colors. These are track jobs. So don't expect show car. I can do show jobs but I'll Ned car for awhile and a lot of cash for one.
