Thread: HELP starting Please?
Results 1 to 10 of 17
  1. #1 HELP starting Please?
    Ok, here's the issue. 91 s13 will not start. Starter does not engage at all. I can push start the car fine.
    -Starter is fine, I have taken it out and gotten it checked three times at autozone.
    -I have tried a new ignition switch, not the problem apparently.
    -I have 12 volts at the Ignition wire right at the starter when I crank the car.
    -I replaced the positive terminal cable from battery to starter.
    -I can (used to be able to) start my car without the clutch pressed in, which I assume means someone bypassed the clutch interlock relay. Actually theres just nothing plugged in the switch at all.
    I am very confused. Even when I attach a jumper cable right from positive terminal to ignition wire at starter, it does nothing but spark.
    Please help, or give any advice possible. Thanks a lot!
    scoob.'s Avatar
    scoob. is offline wagon stuntin' Go buy me some race gas!
    Oct 2008
    your local rice
    could your ecu be out of an auto?
    1%er
    fast.
    I don't believe so. I mean, I've had problems starting over a good little period of time now though.
    I did pull codes a few weeks ago, which is right around the time that the car stopped starting entirely.
    Could my ecu be messed up somehow?
    scoob.'s Avatar
    Oct 2008
    your local rice
    is your engine even turning over?
    1%er
    fast.
    You dont need an ECU to turn the starter over, so rule that out entirely.
    If your car used to be an auto you have a few things you should check, like the shift lock switch and the lower harness wiring. All in all though, if you have constant 12v going to the starter via the fat cable, and the starter is grounded via bolts to the motor (and the motor is well grounded obviously...), then giving 12v to the small starter signal terminal on the solenoid should crank the motor over. If you have those two things and jumping the starter signal directly doesnt turn it over, you have a bad starter. It sounds like this is the case, but internet diagnostics are 50% accurate 10% of the time
    Jan 2008
    Macon,GA
    If it's a real manual car theres a blue relay behind the battery under the fender a lil you should check out.
    He says he sees 12v+ at the signal wire when he turns the key, if so its not the relay.
    Jan 2008
    Macon,GA
    Never know lol. Im not there so im just making suggestions.
    Acworth
    check all your fuses
    could be fuel pump fuse, deppys had a problem yesterday with it blowing
    Apr 2009
    tifton..
    you sir have a wiring problem somewhere...
    check your grounds and check the resistance of the circuits to the starter. lemme know what you find. dont exclude engine ground either.
    ---------- Post added at 03:18 PM ---------- Previous post was at 02:57 PM ----------
    btw, can you hear the starter try to engauge when your starting it?
    just to see, tried another battery?
  1. plz help, starting problem
    By kush240 in forum Motor & Accessory
    Last Post: 08-07-2011, 01:54 PM
  2. Starting problem
    By Bleh in forum Motor & Accessory
    Last Post: 01-05-2010, 02:33 PM
  3. about me, and the S14 I'm starting to wish I didn't have to sell
    By atlanticcoastcustoms in forum Newbies, FAQs & Requests
    Last Post: 09-18-2009, 01:08 AM
  4. SR starting problems..
    By SHIFT_2DRIFT in forum Motor & Accessory
    Last Post: 05-29-2009, 10:28 AM
  5. SR not starting HELP!
    By SpideR in forum Power & Performance
    Last Post: 05-15-2008, 01:31 AM
