Thread: Motor has the hiccups between 2000-3000 rpms...
Results 1 to 10 of 17
  1. #1 Motor has the hiccups between 2000-3000 rpms...
    Oct 2008
    Norcross
    When I drive off in 1st I feel a little hesitation but when it reaches 2 grand on the rpm side and I give a little more gas, it starts to hiccup like a mother. It does this through every gear. What is going on?
    Possibly MAF or CAS?
    Aug 2008
    http://240atlanta.com/forums/showthread.php?t=31205
    Sounds a bit like this, so check your Throttle Position Sensor.
    Use that tool between your two shoulders first and foremost in circumspective decisions.
    No matter who you are or where you go, you are on your own time.
    Be the inferior to no man, nor of any man be the superior.
    Remember, every man is a variation of yourself.
    Dec 2007
    atlanta
    to clear the air, what are u running sr, ka, rb? could be 02, egr, wires, plugs?
    Yashio Factory, (New Pink) . ftw
    Oct 2008
    Norcross
    Quote Originally Posted by monkeyslide View Post
    I am running a ka sir.
    Have you done anything to it lately? Changed anything? Any details you can give us will help. Theres not much more we can do to help without you giving more info or going and troubleshooting...
    Oct 2008
    Norcross
    Quote Originally Posted by ivelS13 View Post
    Will check it out, but does it matter if I have a KA?
    Quote Originally Posted by Vizion View Post
    Yes.
    Different motors are known for different problems so it helps in troubleshooting.
    Marietta\Cumming
    maf could need to be cleaned
    tps could be out of adjustment
    check the plugs, rotor, cap, coil and plug wires
    Oct 2008
    Norcross
    I have done a tune up to it about 2-3 weeks ago. New rotor cap, spark plugs, wires and pcv valve. That's it. I haven't done anything else to the car.
  1. My motor hiccups
    By Neejay in forum Power & Performance
    Last Post: 12-31-2010, 10:35 PM
  2. Hiccups
    Last Post: 03-14-2010, 01:06 AM
  3. My car hiccups throughout the gears...
    By Vizion in forum Power & Performance
    Last Post: 06-19-2009, 10:20 AM
  4. My co-worker has the hiccups
    By J Squared in forum Off-Topic
    Last Post: 09-24-2008, 10:29 AM
