Thread: The SR20 Thread
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 62
  1. #11
    Nov 2008
    d1gpwoody
    if you can find anything on nonturbo SR20DE setups that would be cool too...
  2. #12 nice
    Mar 2009
    smyrna ga
    good info
    Mar 2009
    Snellville, GA
    All that really helps if you need to call nissan
    Call or text me at 770-837-4884 for repair questions. Business is OPEN.
    MCD
    newb question alert! which is #1 cyl on sr.......i know i know. is it closest to timing chain or furthest
    Cylinder #1 is closest to the front of the motor.
    MCD
    thanks
    MCD
    thread pitching for the oil in line on the block is 10x1.25....just in case anybody wants to know
    MCD
    will sr20de crank work with sr20det? that another question to be asked on here to. the sr20de out the of 93 se-r
    Jan 2009
    D-Ville
    thanx for the info
    MCD
    Valve Cover
    69-86 inch-lbs (5.8-7.2 ft-lbs)
    Spark Plugs
    14-28 ft-lbs
    Exhaust Manifold
    If you are looking at the engine from the nose of the car, starting from the leftmost stud and proceeding right, this is the sequence for tightening:
    7-5-3-1-2-4-6-8
    from the middle out in a x pattern
    27-35 ft-lbs
    Intake Manifold
    12-15 ft-lbs
    It has a sequence but couldn***8217;t find it if anybody know please let me know so I can put it up there
    Caps that secure the injectors
    26-33 inch-lbs (2.2-2.8 ft-lbs) ish
    Fuel Rail bolts
    8 ft-lbs in sequence then;
    all bolts to 15-20 ft-lbs in sequence
    sequence is middle, passenger side and driver side
    Oil Pan
    Aluminum section to block
    Large bolts 12-14 ft-lbs
    Small nuts 56-66 inch-lbs (4.7-5.5 ft-lbs)
    Steel pan to aluminum section
    Knock Sensor
    15-20 ft-lbs
    Water Pump
    144-180inch lbs (12-15 ft-lbs)
    Crankshaft Pulley-To-Crankshaft Bolt
    105-112 ft-lbs
    Flywheel to Crank
    94-101 ft lbs
    Camshaft Caps
    6.5-8 ft-lbs
    Camshaft sprocket bolt
    101-116 ft-lbs
    Main Bearings
    tighten to 24-28 ft-lb, then tighten to 54-61 ft-lb
    Rod bearings
    tighten 10-12 ft-lb then tighten 28-33 ft-lb...
    Head
    Tighten all bolts to 29 ft-lbs
    Tighten all bolts to 58 ft-lbs
    Loosen all bolts completely.
    Tighten all bolts to 33 ft-lbs
    Turn all bolts 90 , then turn another 90 degrees
    *Note: When putting the headbolts in please dip them in oil before install.
  1. SR20 T25, KAT Mani, SR20 SMIC, Apexi BOV, N60 MAF, etc
    By iGreek in forum Parts/Items For Sale
    Last Post: 04-15-2011, 07:51 AM
  2. BJdoggydog thread/WTF thread/can't sell
    By WK! in forum Off-Topic
    Last Post: 12-14-2010, 07:26 PM
  3. hks bov ver. 2 // sr20 VC // hks heat shield // sr20 s14 cams
    By optionser in forum Parts/Items For Sale
    Last Post: 05-02-2010, 03:42 AM
  4. WTB sr20 greddy IM,180sx type x stuff,cp piston for sr20
    By NissanDrftr88 in forum Private "Wanted" Classifieds
    Last Post: 08-16-2009, 06:58 AM
