Thread: Ask Marty! Marty's tips and tricks.
Page 3 of 30 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 298
  1. #21
    ATL
    Quote Originally Posted by v-empire View Post
    marty, how does one do a smooth 360? thanks.
    That is not drifting and will get you disqualified from competition. Ask Mike Peters.
    what happens if you drift a stretched tire, and it blows out? and why do people have them even if it is dangerous
    POVERTY
    ATL
    Quote Originally Posted by I RON DON KEY View Post
    Tires blow when they're not stretched too. I don't understand your question.
    Miami
    how do steering angle spacers work?
    its seems that when you put then on your tirerod ends that it pushes the wheels out but then when you would get an alighmnet you would just correct it with the inner tie rod end.
    it confuses me and are then even worth it?
    ATL
    Quote Originally Posted by Nick Jeezy View Post
    Right, you are dialing in your tow but when the rack pushes left or right, it is still moving more because of the spacer. It's hard to explain and I thought the same as you until I put mine in and saw it first-hand.
    virjin jorj
    its in the knuckles, not the thread count.
    www.virjinjorj.com
    ***be virjin jorj, buy a shirt, save a hoe***
    clothing style for Freedom Drifters.
    Virjin Jorj supports 240atlanta.com but is not liable for the actions performed by its members. And no, i do not want to bang you and your girlfriend,may consider married couples.Honor and Loyalty. -------VirjinJorj lifestyle.
    the stock tie rod hits ON the steering rack. the steering spacers or washers push the tie rod outward a little so your rack can move about 5- 7mm further either way you turn the steering wheel.
    aftermarket tie rods do the trick aswell.
    modifying your knuckle is a whole different story. lol
    Jun 2008
    marietta/eastcobb.
    how do suspension components (after market) help with higher speed control? like ruca's toe n tie rods ect. ect.
    Quote Originally Posted by jtbmwi View Post
    u still sellin the item
    greddy turbo
    Quote Originally Posted by cjacob74 View Post
    all aftermarket arms on our cars use either solid or close to solid joints. gets rid of your rubber mushy un responsive nasty stock bushings.
    but individually. the rucas give you rear camber adjustment. which alows you to align your car to the spec you want while at the same ride height you want. stock arms only give like a half degree adjustment.
    if you go too low in the rear and wish for less than a degree of camber. youre going to need rear toe arms aswell to get the car aligned.
    front toe rods give you more steering angle for our cars, also, typically they use a better ball joint and a pillowball joint on the knuckle side. so youre going to feel less *play* and feel the road a little bit better. since its a harder arm.
    front tension rods control caster on our cars. you cant change caster stock, so upgrading to aftermarket arms gives you some caster adjustability. also, you have about a 4 inch rubber bushing in the stock tension rods. and even stock, that bushing will alow nearly an inch of movement. going with a solid bushing here will keep your wheel from moving forward and backwards on braking and cornering.
    the only drawback ive seen from tension rods is that it makes it easier to lock the wheels up in the rain. not really a drawback just learn how to brake better lol.
    May 2008
    A-town
    I'm in my near bone-stock S13 and "KILLIN' IT"... how is this even possible?
    Physics and 240-Law states that near bone-stock S13s can not drift. Am I breaking the time-space continuum?
    KORUWORKS|[TEAM ROWDY]|.:driftmechaniks:.|Ark Performance|Kenda Tires|Mertzanis Racing
  1. Outdoorsman!, Tips and Tricks for cleaning fish
    By ~The_Duke~ in forum Lifestyle
    Last Post: 06-15-2010, 10:55 AM
  2. Ice tips
    By s7_ in forum Off-Topic
    Last Post: 01-08-2010, 10:55 AM
  3. RC Helicopter Tricks
    By Wyluliraven in forum Photos & Video
    Last Post: 10-02-2009, 09:29 PM
  4. New Exhaust Tips w/ pic
    By t3hranger in forum Photos & Video
    Last Post: 03-17-2009, 10:07 PM
  5. some easy magic tricks to do at the bar
    By djQ in forum Off-Topic
    Last Post: 03-28-2008, 03:40 PM
