Thread: Ask Marty! Marty's tips and tricks.
Page 2 of 30 FirstFirst 123412 ... LastLast
Results 11 to 20 of 298
  1. #11
    Andy C's Avatar
    Andy C is offline I should have bought a camry Drift King
    Holly Springs
    and why do people run 295 wide tires with -5 degrees of camber?
    FS: Drag slicks, sr A/C stuff, intercooler couplings, catch can
    http://240atlanta.com/forums/showthr...R-a-c-stuff-IC
    Atlanta
    What's the best meal to eat before a drift event? Would you recommend carbs?
    May 2008
    FEMA Region IV
    Quote Originally Posted by J Squared View Post
    How do toe and caster affect the handling characteristics of your car while drifting?
    I do "believe" toe out in the front will give you quicker initiations and initial response at the expense of straight line stability and tire wear.
    *edit* here you go. Just found this while double checking my thoughts. My Initial assumptions about caster seem to be flawed so I removed it.
    http://www.ozebiz.com.au/racetech/theory/align.html
    wheels can take you around. Wheels can cut you down. We can go from boom to bust, from dreaming to a bowl of dust. We can fall from the rockets red glare down to "brother can you spare.." another war, another wasteland and another lost generation
    How does one "practice" drifting outside of the drifting season?
    And it seems like it will take even longer if events are spread out over months and you only get like 2-3 runs at them.
    (assuming that street drifting is out of the picture)
    - 2003 TL-S - Koni Yellows/H&R Sport springs, Ingalls Stiffy, DC Sports headers, Modified stock exhaust, CAI, Comptech Rear Sway bar, Moog RR bushings/endlinks.
    - 1991 S13 RB25DET S2 - sold, and missed
    - 2011 STI - close future...
    ATL
    Short and sweet, Caster affects your straight-line stability, and the speed at which the car straightens itself back out and easy of steering. With caster, you're either lengthening or shortening the wheelbase of your car. For drifting, I would want the most caster possible for more stability, but some like negative for wheel speed. Toe also affects straight-line stability and steering response. For drifting, unless you're on an oval, 0 toe upfront is what I like to run, and a little bit of positive toe in the rear for stability.
    Of course this is all preference and there are lots of variables involved.
    Quote Originally Posted by MOOREOFSTEPHEN View Post
    my car was tuned in the summer time... hopefully it will be running in a couple weeks or less.
    That being said its now winter time and "should" be cold...
    do I need to tune it again for winter time or can I just work with it myself...
    I run safc II mild tune running about 12.5lbs 280ish hp. Just the basics...
    I heard its stupid to run a turbo timer on a water cooled turbo. Is this true Marty the man???
    More questions to come I just need you on these so far. Plus I have to go poop.
    If you have the money, tune your car as much as you can, but since you're running a pretty mild setup and a MAF and not MAP, you should be fine. Since it is colder out, you might be able to lean out your car a little for more power, but you are fine right now where you stand.
    I'm not a fan of TT's in general. If you let your car sit for like 30 secs or just drive slow right before you reach your destination, you'll be fine.
    Quote Originally Posted by Andycs13 View Post
    Style.
    Quote Originally Posted by Neejay View Post
    The season in ATL starts in February and goes until December. That's only 2 months off. That's better than NASCAR.
    Drifting is car control. Plain and simple. Go to ANY motorsports event you can. Autocross, Rallycross, HPDE's, Karts, anything.
    Quote Originally Posted by Marty View Post
    What's the time frame in between them, on average?
    travis AFB, CA
    do you agree more with formula d's point system or d1's point system? example: 1 and 2 tires off the track in FD is half score and 0 score. going off track but returning to the track without letting out of your drift and possibly even losing your rear bumper on the wall in D1 = more points.
    North of ATL
    Last year it was maybe a month...
    ATL
    If you're willing to travel I bet you could drift every other weekend from February to December. FL up to say VA and as west as TN. Say like a 6-8 hour radius from ATL.
    Quote Originally Posted by omgtofu View Post
    1 Tire drop: Awesome and necessary in some cases
    2 Tires (Tires on same side of car): You're off line and should get a zero
    2 Tires (Both rears): That's a tough call
    But to answer you're question, I'm in favor of the FD Style.
    virjin jorj
    marty, how does one do a smooth 360? thanks.
    www.virjinjorj.com
    ***be virjin jorj, buy a shirt, save a hoe***
    clothing style for Freedom Drifters.
    Virjin Jorj supports 240atlanta.com but is not liable for the actions performed by its members. And no, i do not want to bang you and your girlfriend,may consider married couples.Honor and Loyalty. -------VirjinJorj lifestyle.
  1. Outdoorsman!, Tips and Tricks for cleaning fish
    By ~The_Duke~ in forum Lifestyle
    Last Post: 06-15-2010, 11:55 AM
  2. Ice tips
    By s7_ in forum Off-Topic
    Last Post: 01-08-2010, 11:55 AM
  3. RC Helicopter Tricks
    By Wyluliraven in forum Photos & Video
    Last Post: 10-02-2009, 10:29 PM
  4. New Exhaust Tips w/ pic
    By t3hranger in forum Photos & Video
    Last Post: 03-17-2009, 11:07 PM
  5. some easy magic tricks to do at the bar
    By djQ in forum Off-Topic
    Last Post: 03-28-2008, 04:40 PM
