Thread: power steering relocation for sohc to doch swap
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1 power steering relocation for sohc to doch swap
    Mar 2008
    gainsvagas
    so I am going to do a swap from a ka sohc to a ka dohc the power steering I know it needs to be moved how do I do it and how easy/hard is it can any one help
    Jun 2007
    you get the DOHC lines and bolt them on jsut as if it were a DOHC car
    Pretty easy actually
    Mar 2008
    gainsvagas
    so i need to buy some dohc lines
    Feb 2008
    kennesaw
    yes
    Mar 2008
    gainsvagas
    so just unbolt the sohc lines and replace with the dohc lines that seems easy enough thanks guys
    Feb 2008
    Roswizzle
    You need the lines, resevoir, and i think the pump. Make sure you get all the lines.
    It should all bolt up on the driver side, existing holes and everything.
    Dec 2007
    atlanta
    easy way sohc to sr (me) ma motor sports power steering line 150.
    Yashio Factory, (New Pink) . ftw
    Aug 2008
    You want to put your sohc pump on the dohc or adapt dohc pump to existing brake lines? if the dohc pump is different, you need to replace lines as they said and make your master cylinder will accept these lines. Then you might have to check how much pressure this pump puts out compared to the old one. But, like they said swap lines. If you have too much pressure in the lines, leaks will pop up or braking may become altered and unsatisfactory. Also, when you do the swap BLEED THE BRAKES to get the air and junk out of the lines.
    Jun 2007
    Acworth
    um.. about as easy as breathing. you move the resivoir to the other tower.... and you unbolt the SOHC lines... and bolt in the DOHC lines.... everything swaps easy as pie. you need a dohc resivoir.
    Wes's Avatar
    Wes is offline I have a Haggard Swagger Sideways officer?
    Mar 2007
    Braselton
    The reservoirs will work either way...Im using a SOHC reservoir with my DOHC setup.
    I said 7 long months 39 days to turn my ways around
  1. sohc to dohc swap?
    By 95 240sx in forum Interior, Exterior & Electrical
    Last Post: 02-09-2011, 12:41 PM
  2. SOHC Engine swap
    By S13coupe in forum Private "Wanted" Classifieds
    Last Post: 12-20-2010, 01:58 AM
  3. SOHC power steering pump
    By Wiz in forum Private "Wanted" Classifieds
    Last Post: 02-11-2010, 10:56 AM
  4. sohc to dohc pwr steering?
    By nismonster in forum Motor & Accessory
    Last Post: 09-13-2009, 02:09 AM
  5. doch swap parts
    By rukeydrifter02 in forum Private "Wanted" Classifieds
    Last Post: 08-08-2008, 02:26 PM
