Thread: Headlight Problems Fix
Results 1 to 4 of 4
  1. #1 Headlight Problems Fix
    (Below writeup is borrowed from freshalloy.com and was originally posted by rsxse240)
    Some symptoms: one headlight out, one headlight not coming up, but still illuminates, one or both pop ups not going back down, dim headlights, flickering headlights, there are a few more, I'm sure, but these are the ones I have experienced personally.
    so here's a write up.
    Difuculty (1-10): 4
    Cost: $0.00
    Tools needed: Small phillips screw driver
    2 small flat blade screwdrivers
    dremel rotary tool with straight wire brush
    Time needed: 1-2 beers, depending on how fast you drink them.
    first off, take the clamshell off of your steering column, there are 6 screws in the bottom, you don't need to remove the top portion, I did because I'm doing other work in there too. Once you have the lower cover off, you will see two screws holding the combination switch to the column, remove them.
    Pull the switch straight out, and unplug the connectors.
    remove the two large screws on the white side of the combo switch.
    Use a couple flat blade screw drivers to pry the black case off of the white tabs, and carefully separate the two parts.
    open the enclosed switch unit carefully, again with a pair of small screwdrivers. *DO NOT BREAK THE MELTED TABS ON THE TOP OF THE WHITE ENCLOSURE*
    Open THIS side
    carefully pry out the contacts WITHOUT BENDING THEM! The easiest way is to just put the tip of a flat blade screw driver under the lead, and a finger on the end where the contact is made, and carefully pry it up, it should just pop right out.
    Here you can see the corroded contacts where they were burned from the electrical arcing when the lights are turned on and off. This is what causes all of the problems.
    Get a dremel tool, with a straight WIRE (not plastic) brush, and polish the burned contacts.
    before/after
    I'm sure they will have fallen out on your table when you pulled it all apart, so, be sure you get the plastic pieces that move the contacts in the right way, with the "point" going into the hole as shown here.
    If you can get some electrical contact lube that supreses the arc on the contact, then now is the time to put it on the silver bumps you just polished.
    Reassembly is just opposite of disassembly, so just go backwards on these directions, with the exception of putting the corrosion back on the contacts, and you'll be set.
    -RSXSE240
    -Ken
    Wes's Avatar
    Wes is offline I have a Haggard Swagger Sideways officer?
    Braselton
    Nice find Flip.
    I may have to do this to mine, seeing how I've always thought my headlights were way too dim.
    Have you done this yourself?
    And if so, notice any difference?
    Edit:
    Just thought I'd add.
    I did this last night, and I actually noticed my headlights being a little brighter. Especially the different in my brights.
    I said 7 long months 39 days to turn my ways around
    Quote Originally Posted by godisintheradio View Post
    Nice find Flip.
    Actually the reason I found this one was because last night when I was driving home, I hit a bump, head lights both went out. Hit another bump, they came back. Did that a few times then no head lights at all. Spent about an hour trying to figure if I had a short or what since I haven't really completely hooked up all of the interior wiring in the car. All the car has in it now is a dash, seats and wires.
    I think this just may fix my issue. Symptoms sound right. My blinkers don't work either but I might have just forgotten a relay for them or something...
    Jan 2008
    Sandy Springs
    Hmm mine dont go up or down, they stay up. but they do illuminate. Ill have to try this.
  1. WTB headlight
    By colombianbryan in forum Private "Wanted" Classifieds
    Last Post: 06-18-2011, 03:50 PM
  2. headlight help!!
    By sony4115 in forum Interior, Exterior & Electrical
    Last Post: 10-24-2009, 02:50 PM
  3. headlight ?
    By Stealth13 in forum Interior, Exterior & Electrical
    Last Post: 01-11-2009, 01:13 PM
  4. headlight
    By rdizzle in forum Interior, Exterior & Electrical
    Last Post: 02-09-2008, 11:57 AM
  5. Headlight Fix can anyone come help me!!!
    By Greyka24e in forum DIY
    Last Post: 01-19-2008, 01:20 PM
