Wobble / Shudder when braking from high speed. –
06-04-2008,11:37 AM
This didn't used to happen... and strangely and perhaps totally coincidentally... it started right after I swapped out the Open Diff for a VLSD.
So I've done my own brakes for years. It's had new rotors all around, and I change the pads regularly... I'm not sure what can cause this, but it seems like it's a wobble... and it's only when braking from 60+
I did at one point have my R&P replaced because of my first and last attempt at higher speed drifting on dry pavement. AFAIK everything was repaired correctly. So I don't think that's the problem, unless it is...
Seriously looking for Kouki side skirts, and maybe an S15 steering wheel... I hate the S14 wheel.
If you have S14 front mudflaps I'll take them. (I have rear.)
Also needs: Aftermarket (eBay) SR down pipe to hack on for my KA-T project. Flex section is fine, or not.
95 S14 - 5spd
2002 VW Passat GLX V6 - 5spd
