I have been trying to diagnose a problem for about a week, tried searching threads everywhere and have had no luck so far so.....Car wont start, starter turns, engine turns, got fuel, got spark, just no start. However if I roll it off it will start immediately! And...once it starts it will run fine for about 20-30 minutes, then start cutting out (feels like a spark misfire) and it does it at all RPM's and gets worse as I drive the car. Any help would be greatly appreciated! Here is what I have tried to fix this issue so far....
Replaced Starter
Replaced Spark plugs
Checked Alternator and it is good!
Replaced Battery
Pulled fuel rail to check for O-ring leaks/clogged injectors
Added 4 more body grounds to the car
Checked and replaced the MAF
Checked (with soapy water for vacume/boost leaks)
Replaced Fuel pressure regulator
Checked Fuel pump (it was new when I did the swap)
Swapped ECU
I have heard everything from "check the alternator connections, to Vacume leaks as far as other peoples cars and mine is still fucked!
