Thread: Top Mount Manifold Build
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
  1. #1 Top Mount Manifold Build
    I have been wanting to build a top mount manifold for quite some time now for my KA. I finally decided to bet the supplies needed to build one at minimal cost. I chose mild steel over stainless steel because of the price of the materials and I dont have a welder that will weld stainless. Im using a mig wire feed welder to weld this thing up and it should do the job in 2 passes. I made some test welds with 2 passes and took them to work and let our Certified welding inspector ultrasonically test the welds and the welds had great penetration.
    Materials Im using:
    12 1 1/2" 90 degree but weld els
    2 1 1/2" 45 dergree but weld els
    5 feet of 1 1/2" schedule 40 mild steel pipe
    1 1 1/2" schedule 40 mild steel 4 to 1 merge collector purchased from BMCrace.com for $40. It was cut precisely and the pipes fit together perfectly
    1 T3 mild steel flange from BMCrace
    1 KA 1/2"thick mild steel flange
    Total cost for materials was approx $150. Pipe and elbows were purchased from easter plumbing distributors in Buford GA and the elbows run about $5 each.
    Tools used:
    Abrasive chop saw
    4 1/2" angle grinder
    6" bench grinder
    tape measure
    dial caliper
    120 volt mig welder with shielding gas
    First thing I tackled was the head flange. It wasnt one the fancy laser cut units so I had to de-bur the ports and had remove some material on the head side to get the flange to line up with the ports in the head. I would recommend getting the flange from BMCrace that is ported to accept the schedule 40 pipe. It makes things much easier.
    Next was the collector. It came from BMC race perfectly cut and was an easy fit. I tacked it together and then cut the top where the turbo flange would be mounted
    Here is a jug I made to cut the top flat
    Then I tacked on the turbo flange. I was told to put bolts in the flange when welding it so the holes dont warp.
    Next I started on the runners. The first runner is a PITA and I had several cut and re-tack trial and error fittings but I was patient and got it going. It helps to have someone else to help hold stuff.
    And this is as far as I have gotten. I will keep this thing updated as I progress. I will be happy to answer any questions
    Apr 2008
    Atlanta
    nice!
    06 Laguna Blue - Turbo & Nitrous
    04 Grand Prix White - 2.5L Stroker & Nitrous
    00 Grand Prix White - Supercharged
    i cant believe i can post on the diy threads... whoa..
    anyways.. good post. im so ready to build one... once i get a turbo..lol
    DIY... bc im made of time, not money
    nice.
    I've seen ya posting on KA-T.org and you're making really good progress!
    Woodstock, Ga
    good stuff man
    Lima, Ohio
    bad ass looks like a good start...
    Keep us updated... u might be able to mass produce
    Quote Originally Posted by BH
    Drifting isn't racing.... it's just a way to waste everything you could possibly have.
    Quote Originally Posted by foreverbrokeride
    Your penis should be able to file for emancipation/divorce if you wouldn't poke that... that's criminal neglect...
    hellfire's Avatar
    hellfire is offline Killswitch Performance I made you a kouki but I eated it
    Why didn't you just cut the flange off an SR mani and weld a KA flange to it?
    Tyler
    Lima, Ohio
    daam never thought about that before
    Zippy69's Avatar
    Zippy69 is offline vroom....whoosh!!! Men with guts attack those corners...
    Nov 2007
    Nicholson
    Nice job. Looks like it will be a well built manni.
    It's not how fast you go, it's how fast you go fast!!!
    Everybody wants to party like a ROCKSTAR...
    I'd be happy just to mingle like a cover band.
    http://240atlanta.com/forums/showthread.php?t=18726
    Mah fo sale thread!!!
    Oakhood
    Quote Originally Posted by hellfire View Post
    Tyler
    Y do that when you can build your own?
    Team Stick&Slide #003
  1. Wtb - rb20 or rb25 turbo top mount manifold or I will trade my manifold
    By nismo240 in forum Private "Wanted" Classifieds
    Last Post: 10-12-2011, 11:49 AM
  2. Replies: 2
    Last Post: 03-21-2011, 12:47 AM
  3. sr top mount manifold
    By Biggie-Stig in forum Parts/Items For Sale
    Last Post: 03-20-2011, 09:26 PM
  4. WTB:sr top mount manifold t2
    By whatever210 in forum Private "Wanted" Classifieds
    Last Post: 08-03-2009, 01:42 AM
  5. sr top mount manifold
    By towel_head in forum Private "Wanted" Classifieds
    Last Post: 03-13-2009, 07:02 AM
